sx7001
- Jun 28, 2003
- Sidewinder
ranger1 said:Thanks a lot for posting the chain/sprocket chart. However, I noticed this chart was for the fx/rs/rx & vk sleds. I checked the chart that was for the apex & it said that with either the 20/21 & 22 top gear with 38 bottom required a 68L. 23/24 top with 38 bottom need 70L.sx7001 said:23-38 uses a 68 link chain. Here is a pic from the Yamaha chart.
I guess because the distance between the top & bottom gears may vary from different models of sleds, they must have different charts for specific models.
The RX is the Apex. This chart is the 2011 chart. Specs have changed.
ranger1
Oh thats what happened, they switched up to the 23 in 2011 & the older models were 22.sx7001 said:ranger1 said:Thanks a lot for posting the chain/sprocket chart. However, I noticed this chart was for the fx/rs/rx & vk sleds. I checked the chart that was for the apex & it said that with either the 20/21 & 22 top gear with 38 bottom required a 68L. 23/24 top with 38 bottom need 70L.sx7001 said:23-38 uses a 68 link chain. Here is a pic from the Yamaha chart.
jonnytro
what if u changed the bottem geer from a 38 to a 37 would u get the same resuls.
ranger1
It would raise the gear ratio but not as much as one tooth one the top gear. Might be able to go down to a 36 bottom though, just not exactly sure how to figure out the actial ratio. I think a 37 would be somewhere between a 22 & 23 & a 36 would be between a 23 & 24.....I think.jonnytro said:what if u changed the bottem geer from a 38 to a 37 would u get the same resuls.
It should fit the 68L chain as well!
You might be on to something here, thanks!
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
For ratio just divide larger number into smaller. The result is your ratio and the higher the number, the lower the gear ratio.
sx7001
- Jun 28, 2003
- Sidewinder
nailsandrails said:For ratio just divide larger number into smaller. The result is your ratio and the higher the number, the lower the gear ratio.
Or look at the chart I posted on page one of this thread.
Direct Attack
Ok I got a question ? If lets say I have a 24 tooth top sprocket and change it to a 23 tooth sprocket I will loose some top end mph correct? And I will gain some low end torque correct ?
ranger1
Direct Attack said:Ok I got a question ? If lets say I have a 24 tooth top sprocket and change it to a 23 tooth sprocket I will loose some top end mph correct? And I will gain some low end torque correct ?
The 24 will be faster in perfect ice road like conditions ( next to no friction or drag), but these conditions are rare. Most conditions are snow or hard packed which evidently the 23 will be faster & pull harder in the low end. The 23 will allow the clutches to shift out further than the 24 in poorer conditions.
ranger1
Thanks for the gear ratio formula! My guess was actually pretty close as I figured a 36 with my 22 top gear would be about right, & according to your formula a 22/36 would give me a 1.64 ratio which is just a touch taller than the 23/38 which is a 1.65.nailsandrails said:For ratio just divide larger number into smaller. The result is your ratio and the higher the number, the lower the gear ratio.
Now were gett'n somewhere!! wuhoooo
ranger1
sx7001 said:nailsandrails said:For ratio just divide larger number into smaller. The result is your ratio and the higher the number, the lower the gear ratio.
Ok, thanks again for the chart & good thing I looked at it to see if the ratio's I calculated were correct because Yammi doesn't even list a 36 bottom gear in the chart!
Hmph, back to the drawing board! Oh well, that's the way it goes when experimenting with clutching!! lol
