sbot69
Put 90 miles on my 2014 LTX-SE last year(bought at end of season) and only 100 so far this year. Checked tension last year at end of season. When should I check again? And what should be back out on tension bolt? Owner manual says 1/4 turn but been told that is wrong, but should be 1 1/4 or 1 1/2 back out. Any info appreciated
rbell14
I think my manual for 2015 says check it at 300 miles. Finger tight then back off 1 1/4 turn.
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
My owners manual for my 2015 rtx dx says finger tight, back out 1 1/2 turns. I checked what it said twice.I think my manual for 2015 says check it at 300 miles. Finger tight then back off 1 1/4 turn.
rbell14
Agree with 1 1/2 turns after double checking my manual
sbot69
What type of chain oil do you use? My wife's sled is an arctic cat tz1 with same motor, can I use same chain oil on hers? How much oil does chain case hold?
rbell14
I believe it holds 12 oz. Not sure if AC gear oil is same. Probably would work...
Is it a Pantera? If its a TZ1 its Diamond Drive. Do not use that oil. Use Yamaha Brand or any Synthetic and fill it right to top of window. At 3000mi I recommend cover removal and full inspection of gears. Before that just suck it out unless really contaminated.
sbot69
Yes it is a 2014 TZ1. Any info on what the Sr viper should use? Thanks everyone!Is it a Pantera? If its a TZ1 its Diamond Drive. Do not use that oil. Use Yamaha Brand or any Synthetic and fill it right to top of window. At 3000mi I recommend cover removal and full inspection of gears. Before that just suck it out unless really contaminated.
Synthetic Yamaha,Maxima,Amsoil etc. Chaincase Oil.
