chaincase amount with reverse
ecopter
Worden, Il
Anybody have the amount of oil in ounces for the chaincase on an Attak?
Thanks,
Jon
read the dipstick it is clearly marked.you should probally buy a manual so you know you are fixing it right.the little bit you spend on a manual can save you from wrecking a very expensive sled
Sorry,
Don't have a manual yet and the owner's manual doesn't state how many ounces. I've had several sleds, wrench on 'em all and have never seen a dipstick show in ounces how much fluid goes in. Yes, I can read the arrows, but I'd prefer to know the amount. That's all I was asking.
Jon
Note that its not that important. If you overfill the chaincase, it won't do any harm. This is contrary to what happens when you overfill a crankcase - severe engine damage could occur.
With the chaincase, worst that can happen is that some excess might leak out, but on these cases, I don't even think that that would happen.
I changed mine today using the drain plug because I had some grinding in reverse yesterday. Adjusted the reverse linkage and it's alright now. Didn't take the cover off. About 6-7 ounces came out. But it read above the reverse and standard arrows on the dipstick before I started. I put about 5 back in and it still reads at the standard full mark. Above the reverse arrows. 8.5 ounces would be way over full. Should it read at the reverse arrows? I hate to take too much out.
