Newyamahaowner
- Apr 30, 2014
- Ontario Canada
- 2015 viper xtx se
2004 Mxz 600 Sdi sold
1999 formula z 670 sold
anyone else have this bearing go bad
In FAQ. Bunch of reading but I would recommend switching to the 16 setup. Shaft and all or getting the better wobble bearing.
http://www.ty4stroke.com/threads/busted-chaincase.134857/
And this for the 16 shaft
http://www.ty4stroke.com/threads/2016-5-late-build-viper-changes.137648/
Newyamahaowner
- Apr 30, 2014
- Ontario Canada
- 2015 viper xtx se
Oh if your in Canada and past one year no warranty even if you have the extended warranty
And I am put 2016 parts in it with the new bearing and shaft
09nytro
Yes , I have done several of them , that's why it's a very good idea to pull chain case apart and check everything out ... That upper bearing been a problem with the cats since 2012 ...
Highly recommended to replace that bearing every year or at around 3000 miles ...
I know. Seen it too. I am really pushing it with over 6000 mi on it. Spring I will do the updated shaft and best bearing I can find.Yes , I have done several of them , that's why it's a very good idea to pull chain case apart and check everything out ... That upper bearing been a problem with the cats since 2012 ...
09nytro
It may look good when you take cover off , but it doesn't take long to come apart ... That bearing is cheep for sure ......the shafts are so far apart not much oil gets up there , not unless you use gear lube but that stinks after it gets warm ....
yamaha06
Is it a big job to replace this bearing?
Notenoughtoys
- Nov 9, 2013
- Howell, Michigan
- 2015 SR VIPER LTX DX
Does the bearing make any weird noises when slowing down or accelerating when it is going bad or do they just usually let go with no warning?
Dinner
How many km do you have on the sled when it failed?
Newyamahaowner
- Apr 30, 2014
- Ontario Canada
- 2015 viper xtx se
5000 km no real warning way cheaper than replacing your hole assembly at 2100 tax in
ViperBill
Mine failed at 5000 miles. I replaced the cheap china peak bearing with a much better quality skf bearing. caught mine before it came apart and destroyed the chaincase. Had a lot of pitting in the outer race. Poor quality materials.
09nytro
Really no warning they just come apart ...it's really not that bad of a job to do .. Will take 2 to 3 hours to complete... I would also order the special tool to take off the nut on jackshaft and it also helps to release the collar !
Instead of buying the tool which is not needed on 16 shaft wouldnt a chisel work since its not going to be reused anway since 16 has a clip?Really no warning they just come apart ...it's really not that bad of a job to do .. Will take 2 to 3 hours to complete... I would also order the special tool to take off the nut on jackshaft and it also helps to release the collar !
09nytro
Well if you go that route , but if you are looking for a warranty job Yamaha will not upgrade to new shaft and bearing , they will replace the bearing that's in it ...
Right. Usually they will approve update if you pay the difference though.
