radianguy
- Jan 1, 2007
Obviously but how could ya not notice it??canoehead said:Obviously it's broken and he never noticed, if he doesn't remember torquing it out or in.radianguy said:How did you change the track without removing this bolt?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I'll tell you why. It's a RTX with no reverse! Wanna play betcha?radianguy said:Obviously but how could ya not notice it??canoehead said:Obviously it's broken and he never noticed, if he doesn't remember torquing it out or in.radianguy said:How did you change the track without removing this bolt?
radianguy
- Jan 1, 2007
I don't understand?? You still need to remove the bottom gear to get the shaft out don't ya??
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
mustve been busted, but i see lots of guys running without it so im not worried probly broke the first time i hit the throttle anyways.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
What size easy out are you guys using to get this out? I feel like I'm repeating myself
snomaniac
After reading your post I went and checked and sure enough my bolt head was in that shaft too. I see now why raginyamaha didn't see there was a bolt. That collar sits in the bearing on the case and doesn't fall out. I did the same thing, I was using the directions as a guide but working ahead because some things are easy to figure out so u skip ahead. My bottom gears just came off with the top. I didn't find the broken bolt in the shaft until I was putting the gears back on the shaft. Well anyway radianguy nice eye and thanks, that was a good find.radianguy said:I don't think the bolt head could float around in the chaincase?? At first I couldn't find it either when I took my case apart but after a little search it was resting inside the "collar" (#71 in the fiche) It is sandwiched between the case cover and this collar, could wear the case cover though, heard of that happening.snomaniac said:Great input, thanks guys.I'll go back after it this weekend. Sure am glad that bolt head wasn't floating around in the case or that could be ugly.
radianguy
- Jan 1, 2007
I was baffled when I took my cover off and saw the bolt was broke but couldn't find it?? I asked the guys at the dealer and they said it's got to be in there, I said any chance it could have gotten chewed up by the gears? Not without destroying everything they said! I was stumped, then I found it sitting there in the collar in the cover. Lucky it was in there I'd say, that would have been a mess if it had gotten loose.
