BlineBraap
- Oct 22, 2018
- 17 XF 9000 High Country 153
How do you fill the chaincase once it’s cleaned out and ready to go back together
Lay sled on its side ??
I don’t see any obvious fill port?
Lol look what I did got thrust washer stuck behind bottom gear
Ps don’t do that!!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Read your owners manual.
It tells you how to fill the chaincase oil thru the reverse actuator mounting area.
BlineBraap
- Oct 22, 2018
10-4 thanksRead your owners manual.
BlineBraap
- Oct 22, 2018
I’m running 153 track 270hp tune it’s has 21 tooth top gear and 48 tooth bottom gear tops out around 105mph with this setup is there any recommendations from anyone on here running similar setup I’m worried with it being geared lower it will be harder on chaincase just looking for suggestions I ride trail mostly but do venture off trail from time to time10-4 thanks
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Clean the metal SWARF off of your magnets while your in there, the reverse one up top also.View attachment 142521 Hey folks
Ps don’t do that!!
Would think lower gear ratio would actually be more strain since more torque. Nothing you can do about it anyway. Lots of guys running more hp than that. Run it.I’m running 153 track 270hp tune it’s has 21 tooth top gear and 48 tooth bottom gear tops out around 105mph with this setup is there any recommendations from anyone on here running similar setup I’m worried with it being geared lower it will be harder on chaincase just looking for suggestions I ride trail mostly but do venture off trail from time to time
BlineBraap
- Oct 22, 2018
10-4 she’s back together now all cleaned up magnets and everything surprising how much junk is in there after one season 2200 milesClean the metal SWARF off of your magnets while your in there, the reverse one up top also.
Appreciate the feedback
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Larry, Larry, hes our man, if he cant jump it, nobody can.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Larry Enticer is a tough dude jumping all with that old Yami huh?
TheMogulMogul
whupperofwhoops
- Sep 18, 2018
- Rochester NY
- 18 ZR 9000 RR
Send it!
BlineBraap
- Oct 22, 2018
Just gonna send it
Gonna be a good day!!
