02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
I am swapping out the lower gear on my Apex, and bought a gear and the bearing / bearing cage separate. Can someone let me know if I just have to press the bearing in? Do you use loc-tite at all? Freeze the bearing/heat the gear? I have a press, but was just looking for some advice, as I haven't had the pleasurable experience.
Thanks in advance,
Rick
Thanks in advance,
Rick
Thanks in advance,
Rick
The bearings in the chain case?
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
I
I just did this on my rx1.it was much easier than the bearings in the chaincase halves!I measured the depth of the old bearing before removal&heated the gear(doesn't need to be super hot)I did not cool the bearing but you could.I used my vice to press in the new bearing&verified proper depth.I have about 20 adapters but used the old bearing as an adapter to get the bearing started as all of the adapters just werent quite the right size,just make sure it starts in straight should be quite easy..i did not use loctite as they didn't from factoryI am swapping out the lower gear on my Apex, and bought a gear and the bearing / bearing cage separate. Can someone let me know if I just have to press the bearing in? Do you use loc-tite at all? Freeze the bearing/heat the gear? I have a press, but was just looking for some advice, as I haven't had the pleasurable experience.
Thanks in advance,
Rick
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Yes, the gears in the chain case. The lower gear has a roller style bearing in it, that the axle goes through. Was wondering if I am supposed to just press it in.The bearings in the chain case?
Brotherdan
- Sep 8, 2017
- Belmont,maine
Sorry should have said didn't use loctite!I
I just did this on my rx1.it was much easier than the bearings in the chaincase halves!I measured the depth of the old bearing before removal&heated the gear(doesn't need to be super hot)I did not cool the bearing but you could.I used my vice to press in the new bearing&verified proper depth.I have about 20 adapters but used the old bearing as an adapter to get the bearing started as all of the adapters just werent quite the right size,just make sure it starts in straight should be quite easy..i did not use picture as they didn't from factory
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
Typically the needle (roller) style bearings are sized to be a press fit, although not an interference fit where you would need tons of pressure to install. In my experience while a toolmaker, I used a mild steel pin turned up on the lathe to push in these bearings in a press when possible. The one end was turned down to the nominal bearing ID and to the full length of the bearing so it could not collapse the housing or dislodge the needles. The turned shoulder on the pin that presses the bearing in was sized to contact the outer race of the needle bearing.
Most needle bearing outer housings have a rounded end and a more squared off end that typically has the bearing number etched or stamped. The squared off end is the end you want to push on when installing, the rounded end is meant to function as a slight lead in. Important to start the installation with bearing as square to the gear as possible to avoid damaging the bearing OD.
And no loctite, most needle bearings have a relief hole drilled in the outer housing and you don't want loctite getting inside on the needles.
Cheers
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
OK, thanks for all the information. Will be sending her home!
Brotherdan
- Sep 8, 2017
- Belmont,maine
Sorry new to posting still trying to figure it all out.you won't see any numbers on the bearing as their aren't any.i looked at my old one&both ends sure seem to be the same.if you don't have a machine shop or aren't able to make the special driver that apexallday mentioned you can use the splined collar that this bearing runs on as your special driver.this bearing is a fully caged bearing so it's pretty stout.if you have a press you can use that but most home shops dont.i do but used my vice as it doesn't press in that hard.i have removable alum jaws on my vice which help to protect the gear. I'm sure you will get it no problem
Fleecer
- Jun 13, 2014
- 2019 SRX
I've pressed dozens of these using a bushing driver purchased from Harbor Freight and a hammer. Just pound it out flush......3-4 hits and it's out.
Brotherdan
- Sep 8, 2017
- Belmont,maine
????I've pressedan dozens of these using a Harbor Freight bushing driver set and a hammer. No need to get anal, just pound it out flush. It's not that tight, 3-4 hits and it's out.
Fleecer
- Jun 13, 2014
- 2019 SRX
Sorry....just edited.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
All set with this. Used my hydraulic press and went in smooth. Thanks
- 15K
