jruffell
I know there must be a post out there on this topic but I am not able to find it. I have an 05 and 06 RS Rage that I would like to change the oil on the drive chain. I pulled the side cover off the sled and was unable to find any sort of drain plug. Being that it has a magnesium cover I assume there isn't a drain plug and in order to change the oil you need to pull the whole cover off? Seems a bit extreme for something you should do every season. Has anyone done this and if they have do you need to replace the gasket before placing the cover back on?
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
Your drain plug is on backside of case.If you look up in your tunnel area by chaincase you will see a 12mm bolt head.Thats all you need to do to change your chaincase oil.No need to replace chaincase cover gasket.Hope info helps.
jruffell
Thank you
I am out to the garage to change the oil, you saved me hours of time.
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
No problem......You only need about 8 oz. of oil also if you didnt know.
Elypsis
Same place on an '08 Vector?
Not home (or near the owner's manual) at the moment...
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
Yep
If you add a little to much oil in the chain case, what kind of harm would it do?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
jat59 said:If you add a little to much oil in the chain case, what kind of harm would it do?
It will puke out making a mess under there, no more than 8oz's req'd.
Lots of peeps on here run the same amount with or without reverse with no problems.
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
i suck it out with a myti vac hand vacuum pump. there is no mess!
