Hev
Hey guys. I want to change the grips on my 2010 nytro xtx to something with more grip. I was planning on going with a set of RSI grips. Can I just change to grips without wrecking my hand warmer elements.
dirkdiggler
Suspended
Hev said:Hey guys. I want to change the grips on my 2010 nytro xtx to something with more grip. I was planning on going with a set of RSI grips. Can I just change to grips without wrecking my hand warmer elements.
No you have to cut everything off becuase they are glued to the elements. i just changed mine.
Hev
So what brand of warmer elements do you recommend. The OEM ones are quite expensive I see. What about the RSI ones.
shadow44
RSI's work great, I put some on last season, nice and warm.
phatkid
I've used the rsi warmers and their grip tape on my last 2 sleds they work excellent and are very comfy and grippy...... gonna install them on my nytro this weekend
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
I have had RSI grips and heaters for two years, the heaters still dont work 100%, but they do seem warmer. Make sure you use some grip glue, if you dont the grip will slide off about an inch by the end of the year, also the RSI grips will wear faster then the factory ones, they are allot softer rubber and mine show wear after a year (2700 miles). The grips are awesome though.
YOOPER@HEART
rsi warmers keep my hands toasty and when used with rsi gel grips I was very happy. nice products.
