Changing handle bars - removing grips and pads
jvmaxwell
I bent my handle bars and wondering after i remove the rivet what needs to be done to remove the grips and the heat pads?
What kind of adhesive to use to attach them to my new bars?
Thanks,
jvmaxwell
Yes you will need new elements for sure hard to get them off and new grips to they may be a bugger to get off aswell get the rsi ones to replace them they don't cost as much . GOOD LUCK
I just put a set of Doo alum bars on mine with the RSI Heaters and ODI grips. you'll have to cut the grips bown a bit but they are the best things my hands have felt on a sled yet. Supper easy job though, the whole thing only took me about an hour to change the riser and everything.
