SharkAttak
CAN SOMEONE EXPLAIN TO ME HOW TO CHANGE HYFAX ON THE ATTAK, IS IT EASY OR SHOULD I GO TO THE DEALER, DOESN'T LOOK LIKE IT WILL FIT THRU THE HOLES IN THE TRACK, ANY HELP WOULD BE GREATLY APPRECIATED
SnowBandit
- Jan 31, 2004
- Maine
- www.slednewengland.com
- 2009 Nytro xtx
If I had more than 100 miles on the sled I might know how to change them... Should be like the old viper ones with a screw at the front then just pull them through the track. You might have to notch the hole bigger as these hyfaxs are a little wider.
BA APEX
just lube them up, pull them through the hole. tight but will work.
impalapower
Another alternative, lay sled on its side, pull the screw, take a regular screwdriver and pry underneath up by the screw and pull the fax through the window, pull fax like a bananna peel through the window as you rotate the track to the back of the sled. To put in new, oil the fax and rails, pound in with a hammer, have a piece of wood inbetween the two as you hit.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I made up a slide hammer tool, you can also buy them!
Remove front holding screw, drill pilot hole in rear of Hyfax, attach slide hammer tool, wap, wap, wap, out it comes.
Install new Hyfax by tapping in!
SharkAttak
AWESOME, THANK YOU ALL SO MUCH
cameljockey
I did mine this weekend. What a bitch it is going through the track window. I ended up pulling the skid, piece of cake!!!
