Vectornut
I changed my oil and filter two years ago and discovered two oil rings on the filter when I removed it. It could have leaked but it didn't, so I got lucky. When you change the oil, make sure you drain the oil from the three locations, filter, bottom crank plug and the tank. Then, put two litres in the tank and one litre down the hole where the plastic cap is located at the top of the engine. This will help prevent a dry engine start when you are finished. My dealer says this is important. 05 Vector.
