rx1fastervmax4
Daughter sled 09 vector ltx and i can not find were the noise is coming from. Only does when your just creeping along light throttle. Changed belt, primary and secondary clutch. Tore apart chain case and no change. Just bugging the heck out of me. My apex or rx1 don't do it.
rx1fastervmax4
Also if you grab the brake just slightly it seems not as bad..
snow tundra
Could be missing track clips.Drivers could be bad let us know what you find out.
CaptCaper
- Jan 1, 2007
- Northern N.H.
If your going slow and going over mogals when it does it it's normal. It's the transfer rod. Lot's of posts on it. Search "clunking"
rx1fastervmax4
Thanks..
rx1fastervmax4
Looking at it today on the lift could'nt make it clunk. I than set the parking brake and I could do it when i just squeeze the gas just slightly. Sounds like from the chain case side. Going dig deeper when I get another pair of hands.
punchtech
Had the same problem on my 06 Vector, thought it was in drivetrain, went thru chaincase, drivers, etcc. turned out to be a bad idler wheel and bearing, 25.00 fix, clunk went away! (It was very noticable at low speeds)
iasledder
Check your belt closley for a flat spot on the sides of the belt. If the belt slips at engagement it can cause a narrow spot and that will clunk.
