zipclean
After a couple 1/4 mile runs my clutch gets real hot, should I add more weight to primary. P.S. am running well known clutch kit.Don't know if they were getting hot before kit as I never felt them before kit.Belt looks a little glazed.??????????
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Contact the place you got the clutch kit from and ask them if there is any adjustments you need to make according to the rpm readings on your tach.
Also if the belt looks glazed wash both clutches and the belt with warm soapy water.
