bluegrass
- Mar 6, 2007
o k i am looking for a kit for a 2011 xtx trail rideing most of the time don't really won't one that will give me more top end one that will pull from the bottom end and midrage and one that will pull good when you are in the gas about 30 40 mph and lay right in to it i am thinking from what i have read i should go with a schmidt bros stage two set up what do you think
shadow44
I really like the Drag N Flys with Turks black spring setup....RPMs were in the 8900 range..maybe 9000ish on a longer pull ( but I'm modded ) came in around 3800 and is not jerky. bottom end and mid range pull is hard. It was a night and day difference over stock and another weight setup I tried...they made the difference for me and my combo.
bluegrass
- Mar 6, 2007
i am sorry what is a drag n flys set up i am new to yamaha
shadow44
Super Torquer makes them...they make the Heel Clicker clutch kits aswell..maybe that helps?
Turk
Tech Advisor
Search is a wonderfull option. Your questions have been answered many many times in the past. This is why your not getting any responses.
09nytro
Bluegrass ,,,Don't feel bad that search doesn't work to good for me but i getting better at it
09nytro
If you not good at clutching and tuning , Schmidt Bros makes a very good kit check them out
Super Sled
- Feb 25, 2009
- Summit X
Because you put this in the Nytro section, I'm going to assume to ride one. There are a lot of shops that makes kits for all models of the Nytro. And most are adjustable, and allow you to "tune" your clutch kit for your application. For instance, You will place weights differently in your clutch kit for trail riding compared to drag racing compared to off trail riding, etc.
1. Ulmer Racing (site supporter) makes a great "kit" with a preset recipe for whatever your type of riding may be. Makes it easy. You pay for his expertise tho. I believe the cost is $400.
Here are 2 other great kits:
2. Heel Clicker Drag and Flys (made by Supertorquer systems. Check them out at www.heelclickerclutching.com. Randy there is not a site supporter. However, these are quite popular and work well. About $250 if you call them, or cheaper at Haydays -- I got mine for like $175 there.
Heel Clicker also sells a kit call "2 Speeds", which is apparently quite fast. Lot's of expert tuners use these weights. About $300.
Drag and Fly weights are a great option for your Nytro because lots of TY members have posted lots of great Drag and Fly "recipes" here on TY if you search a tad. Many say Heel Cliuckers are the fastest clutching out there. Some claim they rob top end as the expense for very strong bottom and mid pull.
3. Bender Racing and Boss Racing (both site supporters) both sell the new Super Rats clutch kit. I've recently switched to this from Heel Clicker Drag and Flys, as have some others. It uses little cannonballs in an open cavity in each clutch arm, placing the weight at the exact place it needs to be along the shift curve. Very intriging concept I think. I like this kit alot and I'm glad I switched -- IMHO they pull very hard. I never stop smiling now. Cost is about $275 at Bender. But rather than them I'd recommend getting ahold of Scott at Boss racing off this site and getting them through him. He will get you set up with these with a good preset recipe.
There are other good kits also that I've missed. Maybe others can chime in. The above are just the ones I have experience with.
larrypolaris
I have Ulmers kit right now. Works great. I have two seasons on them.
But like most I am always looking for more.
I plan on trying Heelclicker 2 speeds and Hauck's.
A buddy of mine has Haucks set up in his xtx and he was getting my by a sled or so pretty consistant.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I have the Schmidt Bros clutch kit and it works real well. Engagement is low so it is very easy to ease around and it works great all through the RPM range.
- 21K
