apexdreamer
- Jul 25, 2009
- 08 nytro oft rail extensions 144 2 inch..oft steering relo, Schmidt bros stabilizer and comfort clutch kit, skins front end, fox evolve r 3 front, gauge panel cutout, wrp seat, rox adjustable riser, Yamaha tuner skis, cold air kit
- Minnesota
I just finished installing a clutch kit from Schmidt brothers they call the comfort clutch kit it is absolutely fantastic best money spent on my machine so far on my nytro!!!
yamaha247365
- Jan 23, 2011
- Wisconsin
- 09' FX Nytro
Good to know. Haven't done my clutch yet.
apexdreamer
- Jul 25, 2009
- Minnesota
Just did a 20 mile ditch bang shake down on the nytro ........the lower rpm engagement is awesome, easy load and unload but best is when your in a tricky spot it is sure nice to have more predictable acceleration, looking forward to doing their overdrive clutch work.....
wolfe9904
- Dec 29, 2013
Did you do the helix kit or just the stage 1?Just did a 20 mile ditch bang shake down on the nytro ........the lower rpm engagement is awesome, easy load and unload but best is when your in a tricky spot it is sure nice to have more predictable acceleration, looking forward to doing their overdrive clutch work.....
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Can't beat their comfort clutch. Much easier loading and unloading from trailer and no power loss or top speed. Have had mine for 2 years now and love it.
Pete
Pete
Northern
- Nov 18, 2015
- Whitehorse YK
- 08 Nytro
08 Phazer
So what does the comfort kit include?
Looks like a new primary spring from their website.
Does it do anything to reduce max rpm?
I recently bought an 08 Nytro and it is over reving.
Sent from my bathroom
using Tapatalk
using Tapatalk
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
using Tapatalk
Spring and rollers....It reduces engagement RPM and keeps you lower in the curve throughout the entire range. I really liked the results.
wolfe9904
- Dec 29, 2013
Great, Thanks! I know they have the stage two , which comes with the helix. But I was just looking at the stage 1 for this year to see what kind of a difference that made?? Will the sled still pull the skis with that kit?? or does that take to much out of it.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
2009 Nytro XTX
My previous response was for the comfort kit. I don't have any experience with the stage 1 or 2 kit but would expect them to be more performance oriented tuning clutch performance according to rider & style.
I didn't find that the comfort kit reduced performance at all; in fact, I believe it enhanced it in all regards. Somewhere (I think on the schmidt bros site) there is a graph showing what the kit does and it effectively lowers RPM throughout the entire operating range to keep RPMs in the "sweet spot". Based on the graph, the Nytro's RPMs in stock form are too high.
Again, I liked the results and saw no perceptible negative performance impacts.
apexdreamer
- Jul 25, 2009
- Minnesota
I just did the comfort clutch kit, I look forward to sending them my clutches in the off season for them to do the overdrive machining.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
The stage two is worth every penny! It does a great job of putting the power on the snow. Smooth take offs and a ton of power down low and mid range.
