Laubry
- Aug 26, 2006
- WATERFORD MI
- sr viper
- YAHOO
- larryaubry@ymail.com
Need to know the best spray to clean my clutches do I use carburetor cleaner brick cleaner I just want to clean it up. I know you take a green pad sleeve . And you use some kind of lubrication when you're done cleaning
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Use break cleaner and lubricate only the splines. Not anything else. Just keep everything polished and clean.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Clean sheaves with acetone. And do not lubricate. All yamaha clutches have self lubricating bushings and lube only make belt dust stick worse.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Use a new circlip when reassembling the secondary and might as well throw in some new ramps/buttons while you have it appart.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
MikeWalters
Brake cleaner to get all the crap out, scotch-brite pads to clean sheaves. No oil or lubrication. Polishing your secondary helix ramps with aluminum polish also does wonders.
