Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
I was messin with my 06 RTX today and trying to get the belt up on the secondary.
Im not even flush with the sheeve .
I have 2 thick shims and one thin one in there.
Should I give up?
Belt measured 34.8 mm
Should I give up?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I have a thick washer and the stock thin ones...i start with new belt with thin stock washers..then after about 100 miles i notice i need to replace the thin ones with thicker ones i have.....then after that i was at 1000+miles ,season was over....I got a new belt now and back to square one.
you might consider getting a new belt...although i know you can run these longer ....i dont like the idea of more then 2 washer shims for deflection.
dan
dan
Sidewinder
- Mar 19, 2005
- Ontario Canada
- Waterloo
I have a new belt, but it seems to sit even lower than the used one.
LJ 452
Apexaholic said:I have a new belt, but it seems to sit even lower than the used one.
Is it an 8DN or an aftermarket?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
that is ODD....new belt is wider as it is not worn at all....and will sit HIGHER in secondary.
most sleds with new belt and stock thin shims in back of secondary ,will have belt sitting just above secondary.
dan
SharkAttak
can someone give me the part # to the thin and thick washer's?
Shiek
- Jul 21, 2004
- www.sledbitch.com
- 06 apex gt
washers
90201-061H1-00 WASHER, PLATE (T=0.5)
90201-06037-00 WASHER, PLATE (T=1.0)
ironviper
if you like to keep your belt flush with the top at all times, buy the belt deflection tool that bolts to your secondary and you can adjust it whenever you want without taking off the secondary..
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
There are manufacturing tolerances in width and overall belt length that will determine where the belt rides in the secondary. No two belts are exactly the same.
http://www.ty4stroke.com/viewtopic.php?t=33191
Sidewinder
- Mar 19, 2005
- Ontario Canada
- Waterloo
For the record its a NEW stock belt .
berge75
Can the center to center be adjusted on the 4 strokes?
