clutch play
fiddlersgreen
Newfoundland...The Rock
Canada
Viper xtx le
I'm sorry if this is novice or trivial but my new Nytro has 1100 miles on it an I finally took off the top and side panels.......Talk about relability. I found about 1/8" of play on the secondary clutch in and out on the shaft . The nut is tight but the washers on the outside are loose. The secondary is still loose. Is this normal.
I am used to a cat where my secondary was tight as a drum.
Any help. Or am I just ignorant to the ways of the YAMMY. :rocks: :4STroke:
Yes as ski said.. And if you have reverse you should have eaven more play in turning the secondary... Those Japanes guys are funny but their #*$&@ works!!!
