rtxapex07
I have a 2007 yamaha apex rtx. I am going to convert to a 136 or 144 next year. I am looking for what I could possably do to the clutch this year to not tie up much $$? I saw a post in the past to install a different primary spring, but not sure what to do? I also beleive I have 18 top adn 38 bottom, when I change out the track what gearing do I want? Thought of changing out the top gear and chain to get more top end and not change much on the low end. I was not wanting to put a lot of money in a clutch kit till I changed out the track then I am going to put in a clutch kit, programmer, change the gears if needed, and exhaust. Thanks
Turk
Tech Advisor
Your gonna have to make all your changes 1st then see where your rpm,s are at. Can,t possibly toss out a clutching set up on an idea in your head.
