Chris
- Nov 8, 2005
Ive searched and I cant find any information on changing the rivets in the stock primary clutch. Do I need special tools? How about getting the other weights out? I want to change the weights so I can ride my mountain apex around home (3000')
Chris
- Nov 8, 2005
I think I found what I needed. Seems that I have to punch out the old rivets, and smack in the new ones.
drill thrm out and use a punch.If you don't have a clutch puller you can take the out side primary cover off and get the weights out that way.
Turk
Tech Advisor
If you have a grinder; grind off both ends & punch em out but be careful not to grind off any of the weight itself.
