apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
Hey everyone .. looking to change my stock clutch springs .. I don't race , just looking for a bit more pull without spending a lot for kits .. I was told that if I changed my stock springs to a orange silver orange in the primary and a white in the secondary. The rest leave stock would give me a better pull .. truth to this or no go ... also if this would work do I leave the secondary spring in the same timing holes .? And spring load ? Any input would help .. much thanks
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Start with a white secondary spring set at 3-3
If you are not under revving you don’t need the OSO primary spring.
Fleecer
- Jun 13, 2014
- 2019 SRX
In hero conditions I've run the white spring at 3-2 and it is quite fast for short money invested.
trailanimal
Not racing anymore as well, my best trail set up is silver secondary with 70 twist and the secret yammy primary spring P/B/P part number 90501-600A1. This spring is hard to find listed and has a preload of 20/TF of 119 so makes slow maneuvering awesome Another good spring is the W-P-W a little lower engagement then stock (30) vs (35) TF of 104 vs 101, seems to have bite more mid-range then stock. The first set up listed is best for super smooth riding and not an lose top end and a bite better fuel economy when riding around 5 to 7000 rpm.
yamhaattakman
- Jan 31, 2016
- Renfrew Ontario
- 2007 yamaha attak
Opo primary silver secondary worked great in mothers apex se 2011
