Clutch washer size?
joeltayl77
Windsor, Ontario
I need to tighten my belt and need to add a washer behind my three bolts in the secondary clutch.
Just wondering if anyone knew the size of these small things off hand?
Thanks!
Here you go. 0.5mm p/n 90201-061H1-00 1.0mm p/n 90201-06431-00 $2.95 ea at dealer or online. Is it time to replace your belt?
Hope this helps.
Pete :sled1:
appreciate it!
My belt is fresh.. just a little looser after my clutch kit install for some reason? The top of my belt is even with the secondary. I usually have the teeth of the belt an 1/8th above it... or have the lower part of the belt flush with the secondary.. (kind of tough to explain.. lol)
Is anyone using 2 washers behind the 3 bolts in their secondary?
I believe 1/4" lock washer will work also in a pinch, shouldn't need two washers unless their thin ones.
3 bucks for a spacer.... will quality washers of the same thickness work or is there a balance issue. being its got a huge bending load on the jackshaft bearing i dont see why 0.05mm would make a difference. but if it does I would love to know.
I am using 2 washers each from yamaha , and i am running new YAM belt . IT IS JUST OVER THE CONVERTER .. belts are not all the same even YAM.
