pooner
My wife got my old 2016 Viper LTX DX. She doesn't like how hard the clutch engages. It is stock, nothing done to it. Still running 8JP belt. Has 2100 miles on it. It is too harsh for her. Anyway to smooth it out? She drove my Sidewinder and said if she can get her Viper to shift like the Sideinder, that would be great. Any help would be appreciated. Thanks
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I hear a lot of good things about the soft start primary spring
I have never ran one but I'm sure someone who has will chime in
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Call Barn of parts for a soft primary spring.
mopar yam
- Nov 10, 2011
For sure get one , I can drive in and out of my garage with studs and not spin at all , mine is from schmitt bros and is low engagement around 2500 rpm and no top end loss. BOP is cheaper I think!
Heckler56
- Feb 26, 2010
I picked up a BOP spring. Do you need to pull the clutch to install it, or at least pull the center bolt to slide the plate off?
I removed the six bolts on the plate but could not get it off. Local dealer says the clutch needs to come off the sled to mount this spring but Ulmer youtube shows no need to pull clutch.
mopar yam
- Nov 10, 2011
mopar yam
- Nov 10, 2011
You shouldn't have to pull the center bolt just your six bolts should do it.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
don't need to remove clutch just remove cover make sure you pull cover off square and have a hand on cover there is spring pressure!!I picked up a BOP spring. Do you need to pull the clutch to install it, or at least pull the center bolt to slide the plate off?
if you removed bolts on cover and won't come off it's probably binding
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I'd pull the clutch bolt. That large washer can drag on the bushing inside the cover. Pull the 6-10mm bolts evenly and slowly.
I agree. Don't know why they used a oversize washer.I'd pull the clutch bolt. That large washer can drag on the bushing inside the cover. Pull the 6-10mm bolts evenly and slowly.
tapex_07
- Feb 15, 2009
The split washer should have been smaller to fit inside that bore.
Black7
- Mar 23, 2013
- Michigan
- 2015 SR Viper X-TX
2016 SR Viper S-TX 137 DX
As others have stated; Barn of Parts has a soft engagement primary spring. I put one on each of our Vipers, best, low budget, for drivability, addition there is. IMO.My wife got my old 2016 Viper LTX DX. She doesn't like how hard the clutch engages. It is stock, nothing done to it. Still running 8JP belt. Has 2100 miles on it. It is too harsh for her. Anyway to smooth it out? She drove my Sidewinder and said if she can get her Viper to shift like the Sideinder, that would be great. Any help would be appreciated. Thanks
- 7K
