charlie
i have a 2010 apex and my rpm is low it shifts at 9500 and only shifts out at 10500 the clutchs are stock i tried a white and pink seconday i think i have to take waight out? does anyone have this problem or have a good set up for stock weights/clutching . i also have a 23 gear thanks.....
Turk
Tech Advisor
It needs at least 1000 miles to get rpm,s up where they need to be.
charlie
I have 2600 miles on the sled and I put new helix and weights in this year is that what u meen miles on sled or clutches
Turk
Tech Advisor
If your going to run stock clutching use the white secondary spring from an attak at 60 wrap if yours is a short track.
charlie
Ya I was running a white spring at 70 wrap and on the lake this past weekend I got 110 mph but it would not go over 10 500rpm
yamman
apex clutching
you said you installed new helix and weights what helix and weights?
charlie
Its the stock weights and helex it had a bender kit in it from the dealer and I put the factor parts back in I was not happy with the bender kit
charlie
Turk
Tech Advisor
If the bender kit comes with heelclicker weights & helix do you want to sell it?
I may as well not be happy with it.
pm me with a price if interested.
charlie
Do u think I should take weight out or is there a good weight I could by I and looking for lake running
Or a clutch kit that it really good
RollRite
- Dec 16, 2004
- Pickerel , Wisconsin
- 2011 Apex
I have 2011 SE 1,200 miles and only get 10,400 rpm with speed at 104
woodysattak
- Apr 15, 2010
- Union Grove WI
- 2017 RTX LE
- Waterford WI
top end
The stock weights should pull excellent top end. I have done tons of testing now with four different weights. And hauck and stock weights seem to have the best top end. And this is at 10500 -10600. I will post my results later but these weights really pull on top. Tried Dalton and drag n flys and I don't think they have the top no matter what rpm. Thanks Kurt
