4stroker
Just was wondering if there is any reason for waiting to "break in" the new RX before installing a clutch kit??
Will the characteristics of the sled change as the initial mileage starts piling up enough to alter how the clutch kit functions. (ie: rpm's usually increase slightly as the motor "loosens up") Or will the clutch kit " underachieve" until the sled is broken in slightly?
I'm going to install one at some point, I'm just not sure if it makes a difference if I do it with "0" miles.
jtssrx
I would say ride it stock just so you can see the improvement you will get from clutching
monker
I'd have to agree with jt. How do you know if you made any improvements without riding it first?
- 7K
