MAMILLA
On my 09 when im climbing a hill im only running 8100-8300 i thought i am supposed to be around 8900 under a load. any advice
Turk
Tech Advisor
Lighten up the primary weights.
mtncat
Call starting line products and get a purple #40-78 and run it in the 1-0 setting should put you at 8900-9100 on the hard pack 8600-8700 in the deep.
Unloading at 8500Ft. Also running a 19 tooth top and 162 PC with a fox float cat skid
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Check to make sure your throttle cable is pulling all the way too. Mine wasnt on my first ride on the sled. Only pulled 83-8500. Adjusted the cable, instantly pulled 88-8900.
