Cobra extroverts?
Grand Rapids, MI
I just bought a cobra track fully clipped. I had some real ratcheting problems with my stock ripsaw. Am I going to need extroverts or will I be fine with the stock sprockets with a full clipped track? When I find some more money, I am going to stud this track also. I will be adding some extra protection in the tunnel. Is there any clearance issues with 9t extros?It is a nytro rs
Well, the new track will be tight at first, as all new tracks are, and you might not ratchet as much. But once it has worked itself in, you will most likely ratchet as much or more with the full complement of clips. I'd personally throw on a set of extroverts when I have the drive shaft off of the sled.
X2 if you can do it now I would.
