Code 11
Brutus
Age
45
Winnipeg
Canada
2010 yamaha rs viking professional
Hi I have a 2006 Apex moutain that I just bought. When I brought it home in the cold it had a hard time starting long cranking and finally fired. It worked great in a heated garage no issues. Went to go out riding last night -30c, when we got to our location the sled just cranks and has an active code 11. I brought it home warmed it up and no change still cranks active code 11, I cant hear the fuel pump and have remove the cyl. Id sensor. Is there a way to test the sensor? I have 4.5v at wht/blk and ground at blk/blue.
Any help would be greatly appreciated.
That is for a no crank issue looks to be the starter solenoid in that post.
There were several issues identified while searching for an answer to code 11.
Hope you find yours.
What are the 3 wires at the starter solenoid used for? They were corroded after cleaning the engine starts no codes.
I don't have a wiring diagram.
One of them supplies power to the FI circuit.
