Nosey
- Dec 11, 2021
- Illinois
- Sidewinder
I put my sidewinder on is side almost rolled it
Now it flashes code 30 and temp warning light dealer changed the temp sensor that code didn’t clear and the code for the oil sending unit switch code came back
Dealer want to reflash my computer and they didn’t change the sender or the switch does this sound correct actions taken? Any help
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
What did you end up finding out. A buddy of mine is doing the same thing. Replaced both oil sensors and code came back. ThanksI put my sidewinder on is side almost rolled it
Nosey
- Dec 11, 2021
- Illinois
- Sidewinder
Still lights up they said they changed out the parts associated with the code and ran some test dealer said everything is within the perimeters that they would expect to see so they put it back on the flash .I have put on about 1000 miles still need to take it back to be reflashed to see if the code goes away .
I will say ride at own risk
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
What tune do you have. My buddy says it still runs great just has that code. Thanks
FJRwithSkis
- Nov 22, 2020
- Upstate NY
- 9000 Limited
After I sent my ECU in for a SS flash update I had the same code, sent it back and it was worse, never seen that ecu again.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
That’s what he has ss tune
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
What do you mean by it was worseAfter I sent my ECU in for a SS flash update I had the same code, sent it back and it was worse, never seen that ecu again.
Nosey
- Dec 11, 2021
- Illinois
- Sidewinder
HurricaneWhat tune do you have. My buddy says it still runs great just has that code. Thanks
Nosey
- Dec 11, 2021
- Illinois
- Sidewinder
Runs goodHurricane
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Yes that’s what we have runs great. I actually emailed dave to see his thoughts. Maybe he has to clear the code who knows thanks for the information
Nosey
- Dec 11, 2021
- Illinois
- Sidewinder
Yep pretty happy except for the code flashing at me let me know if you get it reflashed and the code goes away
Did you’re buddy put his on it’s side as well ?
I am putting on an ultimax belt
Did you play with the weights at all for the clutch
FJRwithSkis
- Nov 22, 2020
- Upstate NY
- 9000 Limited
What do I mean? I ran a season with with the SM bundle, ran great. Heard about the "SS" update and sent it in, got the oil pressure code and sent it back in. After I got it back I had 4 different phantom codes that don't exist, oh well, #*$&@ happens....luckily the vendor went the extra mile and replaced my ecu, now I run a different setup and couldn't be happier.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Yes my buddy put it on its side. No damage just the code. Not sure if he wants to do the reflash or not. If it fixed the code I’m sure he will. I guess that’ll be a question for dave. We use thunder clutching set up by them.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Did u get the code by putting it on its sideWhat do I mean? I ran a season with with the SM bundle, ran great. Heard about the "SS" update and sent it in, got the oil pressure code and sent it back in. After I got it back I had 4 different phantom codes that don't exist, oh well, #*$&@ happens....luckily the vendor went the extra mile and replaced my ecu, now I run a different setup and couldn't be happier.
FJRwithSkis
- Nov 22, 2020
- Upstate NY
- 9000 Limited
No, I got the code by sending it in for an update, guess I should have left it alone but I upgraded to a 2 1/2 exhaust and figured I'd get the SS updated bundle while I was at it. Its a shame too, I was looking forward to seeing how much better it was. ran amazing with the SM bundle.
