Tuned sidewinder sd30 code
code-sd-30-after-i-rolled-right-side.164380
If that doesn't work, take it in. Did the cold start break the oil pump drive perhaps? Shouldn't have, but you never know.
Update: Knapp, your idea was pretty close. Turns out that the oil pump sprocket was spinning on the shaft. The bolt was tight but the two flats that mate the sprocket and shaft stripped out.
