feysfunworld
- Dec 20, 2008
08 nytro code 30 help
xtx18
- Jan 3, 2013
- sparta wi
- 2011 Yamaha nytro xtx
- Wilton wi
Nytro code 30 = "Engine stops when an oil pressure drop is detected."Â
Check your oil level, and the float in the oil tank. Next thing is the oil pressure sensor...
feysfunworld
- Dec 20, 2008
Put some oil in thats not it!! Float??
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Did you overheat it? Theres an oil pressure sensor switch beside the oil filter, follow the wire see if its melted anywhere
feysfunworld
- Dec 20, 2008
Took off skid plate seems like there was oil coming from somewhere oil on skid plate
feysfunworld
- Dec 20, 2008
But there is oil on the skid plate
kopenytro
Code 30
Check your oil pan to see if it is cracked or compromised in any fashion.
I had mine crack on me a few years ago after coming down hard off a drive way approach.
Also check to see if your sensor by the oil filter is ok.
If neither of those are the culprit, start looking at the oil tank and lines on the brake side of the sled.
Hope that helps.
Kope
Hope that helps.
Kope
feysfunworld
- Dec 20, 2008
Oil in the air box! ! I was stuck at an angle
1Jason506
- Feb 18, 2021
- New Brunswick
- 09 Yamaha Nytro xtx
Does the oil level float give the same code as the oil pressure sensor?
