Code 42 and 84 (VK Pro 2006)
Emnitec
Lulea
Sweden
Yamaha RS Viking Pro -2006
Hello all,
The speedometer is dead so I get the code 42 which is understandable. But, after a little while I get code 84, and when I drop the gas the T.O.R.S system kicks in and dumps the rpm and the motor firing back.
My question is, does the speedometer failure have this effect on T.O.R.S so it is all natural with a broken speedo or could it be two separate failures. I've tried to search here but I really can't find the "right" answer for my question, thou I'm sorry if I missed it...
TIA
/Pierre
Not having the speedo sending info to the computer will affect how the motor runs. Same thing happened to me. Gauge was not working and sled started to back fire and would hardly move. Turned out that the plug to the speedo was loose. Snapped plug together the right way and worked fine again.
Sounds right to me, they are definitely related
