p0wd3rp1l0t
hey fellas-wondering whats a code 81-started up my sled the other day and it flashed a code 81-dealer is bout as helpful as a sharp stick in the eye-anybody have any info?
I may have that in my Tech book. I can take a look tonight if no one else gets to it before me...
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Look in the owner's manual.
SRXSRULE
That is for the fuel sender. Unplug the connector and use an ohm meter to check it. Make sure you check the sender side and not the harness side. Its only a two wire connector just just zero your meter and put one lead to each wire. With a full tank you should see 4-10 ohms. Empty tank reads 90-100 ohms. Good luck......It might just be a poor connection too, check for a loose fit and make sure there is no corrosion in there. ===SRXSRULE===
p0wd3rp1l0t
is an ohm meter a voltage tester? if not i'll have to bring it to my dealer.
SRXSRULE
Most volt meters have an ohm setting on them. Ohms is the unit of measure for resistance. ===SRXSRULE===
p0wd3rp1l0t
oh alright, i'll give that a shot then
towing
I think there is a little mistake here... propably different between RX and Rs serie
I have the shop manual for my RsVenture which is the same for the Rage an the 81 Code is for the grip warner disconnected or short-circuit ...
For the fuel sender on the Rs serie, the warning light, fuel meter and fuel level warning indicator will flash with no code on the display
The resistance for the grip warner is very low and should be between 1,53 and 1,87 ohm on each side . Search for a disconnected harness, corosion or an open circuit on a grip warner.
Good luck
Alain
Good luck
Alain
snowsweat
Hey pimp, do you use an electric face shield? If you hook it up to the wrong circuit, the change in resistance is often enough to produce an error code. Connect the face shield to the headlight circuit (if you use one.)
Indy
CODE 81 = your sled is trying to communicate with you, it is saying "PLEASE TAKE ALL OF THE UGLY ORANGE ACCESORIES OFF OF ME!" LOL
