wacnstac
Got an engine lamp with a code 81 out of the blue today. Looks like the fault codes that used to be posted in this forum are gone now. Saw on some other forums that this might be an open or shorted hand warmer. The warmers seemed to be working fine.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
wacnstac
Actually found the service manual after I made my post. Now on to what would suddenly cause this. The grip warmers seemed to be working finem
wacnstac
Also I'm guessing it must be talking about the front grips as the rears were off. No way to tell if they are open or shorted
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
The rears are independent run on DC through a switch and fuse so those ain't it. There's something with the fronts, probably a short to ground. They might still work but if the element is wearing through to the bar, it might be shorting. As per the manual, check the resistance and shorts to ground..
wacnstac
May just have to ride with the hand warmers off for the rest of the season. Way too much now and good riding and not enough time.
