AJ HKP
- Feb 25, 2007
I just recived Code 85 . I know what it is but I want to clear the error massage. Any suggestions
Lachenma
- Dec 29, 2006
1st i would read the sticky at the top of the Phazer forum.
2nd i would try out the search feature.
ps 1st option will tell you what you need to know.
68Johnny5
- Feb 25, 2007
- BC Canada
- johnpiccolo.ca
AJ HKP said:I just recived Code 85 . I know what it is but I want to clear the error massage. Any suggestions
1-Hold down the "select" and "reset" buttons together.
2-Turn on the Ign., and continue to hold until "diag" is displayed.
3-Release both buttons, then depress them both again until the display changes to a Number.
4-using either "select" or "reset" scroll untill you see #60. There should be a small number below it. (error code)make note of number.
5-now scrol to#64, and again a small number is displayed below it. This is the error log(counter)
5- If it is not "zero" press the "gripwarmer button to return to zero.
6-Shut the Ign. off, wait...., then back on again. If the Condition that caused the error is no longer present, no codes will be displayed.
***Hope this works, I'm working from memory and haven't done this for some time.
Johnny5
phazered69
- Feb 3, 2007
I had a code 85 and the sensor acually came unhooked.
rfabro
Disconnect battery for a few minutes is all you gotta do to clear codes. Just like a car.
Yellowknife
- Jan 25, 2004
- Yellowknife, NT, Canada
- www.youtube.com
I keep hearing this from you guys, but when I have a code and fix the problem, all it takes is turning my sled off, then on again and the code is gone.
