Honestly I believe it is a Retarded ECU throwing the code. Or whomever programmed it.Hopefully its just a fluke thing. Disconnect battery and try again. Also make darn sure your battery and its connections are 100%.P2300 code is for the coil "A" (clutch side)
I have test the coil and the resistance is within the specs according to the service manual. I also remove the spark plug and it seem to be ok (not fouled) Do a bad spark plug throw this code?
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
I just try to disconnect the battery but it did nothing.
What voltage is it at?I just try to disconnect the battery but it did nothing.
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
12.7v
swap coil wires. This code is on even when its not running right?
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
No only when running at idle. If I hit the gas 2-3 times it desapear until I stop the engine and I restart it.
Well you can at least swap coils and see if the code moves too.
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
I already swap the coils... without sucess
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
Tomorrow I will put a new spark plug, maybe its the problem...
So even after swapping coils it was the same code? If so it has to be in the wiring or connections. Since if it was the coil it should have changed code.
Yes could still be the plug.Tomorrow I will put a new spark plug, maybe its the problem...
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
I will reverify connector tomorrow and put a new spark plug. I will keep you uptaded.
If old gas went through it could just be plug. Hope so. Night
