Cold engine Starting problems 2007 VL
apeddigrew
St. John's, Newfoundland, Canada
hi all,
has anyone out there experienced cold engine starting issues? cold engine only that is. It is an aftermarket starter. i hesitated to state this as too many will blame it immediately. there was an unexplained shutdown of this machine before starter was replaced also. all comments and thoughts welcome.
cheers,
ap
Can you describe the what the problem is? Won't turn over, won't fire, turns over too slowly?
VL COLD START ISSUE
Many Many apologies to Sled dog and all VL & MP people. i posted same query on General Discussion and got sidetracked over there.
anyone with comments or observations on that thread (copied below) please let 'em fly!
thanks a bunch!
cheers and happy sledding all!! (wont be long for some of us!!)
in the morning after sitting outside camp all nite the machine
required 10-15 attempts of turning the key before engine would turn over.
later this worsened to 20-30 attempts to get sled off trailer after 3.5 hour
drive, (with cover on). once she turns over, she starts fine and continues
to do so. hasn't happened when starting periodically during summer.??
cheers,
ap
Did the starter relay click or did you get no sound when turning the key to
the cranking position? Once it did crank did it crank fast or slow?
No clicking, just nothing at all, then after many attempts normal cranking, and starting ok.
Back to top
Blue Dave
Life Time Member
Posted: Wed Oct 30, 2013 10:08 am Post subject:
Welcome to TY! Please add your location to your profile.
What is the issue exactly? No cranking, slow cranking, cranking fine but no fire? Please elaborate.
_________________
2007 Apex GT, Ice Ripper XT Track, Ulmer Racing Stage 2 Clutch Kit, 23 Tooth Top Gear, CR10EK Plugs, Bergstrom 8" Triple Points, Sled Start HID Headlights, Rear Heat Exchanger, Low Snow Wheel Kit, 4th Wheel Kit, Sled Start Remote Starter, Yamaheater w/ Boost, Digital Temp Gauge, Oilight Front End Bushings, OFT Racing Steering Bushings
Back to top
dexter
Posted: Wed Oct 30, 2013 10:40 am Post subject:
tight valves can make cold starts an issue... like blue dave said though, what is the issue?
_________________
2005 RS Venture 5,500 miles
2010 RS Vector 5,030 miles
2006 Rhino Camo
1980 Yamaha xs 850
1979 Yamaha Enticer 340
Back to top
yamahahaapex
Posted: Wed Oct 30, 2013 11:25 am Post subject:
intersting....I have a 2011 Apex that even when I witnessed it being started for the first time on a cold engine that to this day in any temperature it needs two to three tries to get it running. I now just hold the key a bit longer. I have sent videos to Yamaha techs and no word back for almost a year so it seems they dont have an answer either but didnt bother contacting me back about it
_________________
07 attak
07 phazer mtn lite
07 apex mtn se
11 apex xtx
09 grizzly 700 se
03 v-star 1100
09 R6 Metallic Orange
09 Roadliner Midnight 1900
2010 Ford F-150 XTR
Back to top
RTX
Posted: Wed Oct 30, 2013 12:30 pm Post subject:
It dont want to start when cold?
Like it turns and turns but just dont start?
Mine did that and it was the pick up for the stator went bad. I had to replace my stator.
Once it warmed up you could shut it off and it would start fine. But getting it started was real difficult
Back to top
Handy
Posted: Wed Oct 30, 2013 1:50 pm Post subject:
From what I'm reading above there is no clicking, no cranking (slow or fast) just nothing. That would make me look at battery contacts first, starter relay second, starter soleniod third and ignition switch last. It is obviously an electrical contact issue. Moisture in the starter relay will freeze in cold weather and not allow the contact points to close. I say the ignition switch last because they don't fail very often. The starter soleniods have been known to fail on occasion but the relays are prone to picking up moisture especially if your running a lot of powder or breaking trail.
_________________
Quality never goes out of style
Back to top
Riceburner
Life Time Member
Posted: Wed Oct 30, 2013 2:11 pm Post subject:
Not uncommon. 90 % of the time it is the relay having some moisture in it and when the moisture freezes the relay does not operate.
I relaced the original on my 06 and carried a spare after that but never had another problem.
Yamaha got some bad ones from their supplier in the early years of the Apex.
If you take it out and heat it up under your jacket for awhile it will work.
Under $20:00 to replace as I recall.
_________________
2011 Boosted Apex XTX [ MCX 290 Turbo]
Fox Float X Reservoir Shocks, AEM Guages, Lake Effects Riser, Excell X Wheels, Dupont Slides.
2013 Apex SE, Bone Stock, For now !!
Back to top
thor452
Posted: Wed Oct 30, 2013 2:53 pm Post subject:
mine did the same thing it is most likely the selinoid for the starter they can get moisture in them and corode yours may not be nasty yet but may be iceing up if this is it it will get worse and leave you stranded.
_________________
2012 XTX RTX mirror kit nytro hard plastic hand guards hid lights ice tech pre studded track skid plate snow trackers lake effect 2.5 pivot risor...
Back to top
couch
Posted: Wed Oct 30, 2013 5:02 pm Post subject: Re: Cold engine Starting problems 2007
apeddigrew wrote:
hi all,
Sounds like the relay - common problem on the Nytro - or similar electrical issue. Pull the plastics and put dielectric grease on all electrical connections. Most of the connectors are high quality but the relays and fuses tend to be less well sealed. Doesn't get real cold on the Avalon compared to a lot of other riding areas so unlikely its related to the temperature.
Back to top
Blue Dave
Life Time Member
Posted: Wed Oct 30, 2013 5:32 pm Post subject:
I see that you edited your post with more info. I agree with the others that if you are not hearing any click that the issue is probably the relay. If you can reproduce the problem it will be real easy to troubleshoot with a meter.
_________________
Back to top
RTX
Posted: Wed Oct 30, 2013 6:12 pm Post subject:
After reading what you added to your post, i also agree it is most likely the relay
Back to top
apeddigrew
Posted: Wed Oct 30, 2013 7:57 pm Post subject: Cold engine no start
Thanks very very much to u all. Plenty of leads there obviously starting with the relay.
Cheers All!
Back to top
Yamadog
Life Time Member
Posted: Thu Oct 31, 2013 4:17 pm Post subject:
I also chased this type problem on the wifes 05 RX-1. we would ride - park the sled for the night next morning turn the key a bunch of times without anything. I switched the relays on the 2 sleds and no change sometimes it would do it and others not. eventually it did it in the heated shop. I went through everything and it turned out to be the key switch. I had several spares from other sleds and it never happened again.
_________________
Waiting on 2014 SR Viper XTX SE with MPI Turbo YAMAHOO!
2013 Rush Pro R800 Switchback for sloppy days
Basically my advice is:
If you hear the fuel pump and the starter does not turn over look at the starter relay. If you do not hear the fuel pump but the starter turns over check the fuel pump relay.
If it just won't turn over fast enough I would suspect the battery. If nothing happens at all I would look for a loose battery connection and look for a new battery.
Boosting the battery is not always a good way to check if it is the battery. Better to put in a 12V battery that you know is good to test.
Hope this helps.
It's right in front of the fuse panel. You should see a big red wire going to it and another going out to the starter.
