speedjunky
In Quebec this week 20 below and I couldn't get my 06 GT started. It is not the fuel pump relay. It is pumping fuel when I turn the ing. switch on. My problem is that when I try to crank over I can hear the starter relay click once, then nothing. I have a good battery. Funny thing is that a guy there the same morning had the same problem. The next day one of the guys that I stayed with had the fuel pump relay problem. Has anyone had the problem that I described? I and going to try replacing the started relay.
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
speedjunky said:In Quebec this week 20 below and I couldn't get my 06 GT started. It is not the fuel pump relay. It is pumping fuel when I turn the ing. switch on. My problem is that when I try to crank over I can hear the starter relay click once, then nothing. I have a good battery. Funny thing is that a guy there the same morning had the same problem. The next day one of the guys that I stayed with had the fuel pump relay problem. Has anyone had the problem that I described? I and going to try replacing the started relay.
It's your starter relay, under the airbox next to the battery on the right.
speedjunky
Did you have the same problem? I think your right and that is my first thing to try.
SIMMER
Yup....happened to our group in -30C temps. Exact same symptoms, "CLICK" when you turn the key.
The fuel relay sympton turns over but just doesn't fire.
The sled that had the problem was an 06ApexGT. Lucky we had a mechanic with us and he "jumped" the relay to turn it over.
