No lights
attakmod
Labrador
Ok I posted a problem before about not starting and it was the fuel pump rely. This happened to me again so I put the new one on and even at -25 there is no problem but now it takes some time for the lights to come on, so whats up with that?
Another thing is my bud had the same problem with the fuel pump relay, whent out and wouldnt start, he had a spear one in his pocket, put it and no go on the fuel pump, after an hour she started anyone know whats going on?
Next time fuel pump relay gives you grief like you had before just turn/hold the key and keep cranking engine over for about 10-15 seconds and she will fire up. Providing your battery is in good shape. Read it on here somewhere, tried it and it works.
The lights are known for not coming on right away in cold. Its happened to me and others on the site.. Mine came on within 5 minutes when it happened. From what I understand its another relay that controls the lights and gets moisture in it from time to time..
Are you washing your sled alot? Its moisture for sure
Replace all 4 relays above your left foot. There is a new style relay that is better to resist moisture buildup. Had the same problems and repaced all 4 and everything is good. There like $10-15 each, replace them and carry a spare and be done with it.
Are the new style relays covered under warranty? They should be if it's such a common thing and that they've actually improved on them since.
