Crazydiamond
- Nov 15, 2012
- Appleton, WI
- 2011 Apex SE, 2007 Phazer
My '11 Apex SE has failed to start twice on cold mornings. Both times the temp was about 0 degrees F. It will start but then stalls and will not restart. I've tried holding the key on after it starts but it stalled after about 5 seconds. Holding the key on has worked in the past sometimes but not always. I had to pour hot water on the thermostat housing to get it to restart and idle properly. Is there any better solution to this annoying problem?
