Constant 12volt wire under dash?
Why dont you just use the Red cable coming off the battery? The only other thing its used for is to charge the battery if necessary! You could use a bolt and an eye connector. It will supply whatever you power to what ever you need but just remember to add an in line fuse.
There probably isn't any hot wire under the dash. But I would test the lines that go to the ignition switch to see if one might be hot. That would be the next closest spot to pick it up. What are you trying to power up?
