flyLow
I'm looking for some knowledge about a couple coolant leaks I have. The sled is an 09 Nytro with a Boondocker turbo on it. I bought the sled with the setup on and don't know much in general about sleds but I'm learning as I go. I recently found a coolant leak that is near what looks like a rubber boot coming from the block. There are 3 of these in a row, one for each cylinder I'm guessing. The coolant is leaking from what looks like one spot.
I also found some coolant under the belt. It is puddling on the bottom plastic under the belt but I can't see where it would be coming from. Any ideas on either of these spots (what's causing it, is there a fix, etc...). Like I said I'm new but will tear into it if I have to. I just need to know what's going on as a first step and then get to fixes next. Thanks in advance.
flyLow
I had some time this morning to look into the problem a bit more and I think a hose came loose allowing coolant to leak out which made its way into multiple crevices. Now I just need to fill with more coolant and run it.
