Red coolant light?
mateo
BC
Question, have a full reservoir, exchanger warm, and full rad. But on first start I get the red coolant light coming on. If she warms up a bit, it goes away.
Any ideas? Wondering if it's just a sensor...
I belive it also means its warming up I get it on my nytro and phazer... Just let it run till it goes away and unless it sits for a while like a few hrs u shouldn't get it once its warm
Its normal I have owed four fourstrokes everyone does it unless engine is warmed to a certain temp. So yes your right its a sensor do not touch the throttle at all before the light goes out or fouling your plugs will possibly occur trust me I have done it on my apex.
Hmm Ok.
Find it a bit strange since its the first time Ive seen it ever. (5 rides now). Maybe I simply missed it before.
THanks for the info.
It comes on when you first start up your sled with a cold engine. Once the motor gets up to running temp, the light goes out. Only time I see it is when I first get ready to ride. Nothing to worry about.
Was the sled in a heated garage or ? If so this would explain the light not coming on or at least for not very long.
i keep mine in a heated garage and i still get it. It has nothing to do if the engine is warm like temp it is warm because its ran for a while
I know on my R1 it reads lo until it reaches 40*... And then you're clear to ride it.. It would be the same for this light, remains on until a certain temp is reached, then goes out.. Gets to that temp faster in a heated space.. etc
Also when the light is on the revs are limited by the ecu. Had to move my sled once while it was on and found out that way.
Don't even try to move your sled when the red light is on. Very easy to foul a spark plug, which a swedish snowmobile magazine found out the hard way (and after that the Nytro was a piece of #*$&@ in every aspect, funny enough...).
i thought there was a problem when i first got my nytro too, but after i checked the manual thats how they work. its kinda nice, there is no guessing when it is warmed up and ready to ride
