kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Hey guys,
Wondering how you go about cleaning a coolant system. Mine has some black particals stuck on the bottom of the coolant tank and I dont know what from. Normally that would be a bad head gasket but it runs perfect and has never blown a head gasket.
Just vinegar and water to clean it and hope its just crap from when the head was shimmed?
Do all of you engine guys that pull heads, etc have a perfectly clean coolant system?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
just clean it and be done... its it not pushing coolant its okay
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
X2, it's common on every engine. Likely remnant debris or residue from the engine block and head casting process that gets dislodged from the thermal cycling and coolant flow under operation.
Diesel mechanic's use Dawn dish soap & water to clean the coolant systems on Big trucks. I don't see why it wouldn't work for your application. I have done this on my Semi's also & it seems to work just as good as the radiator cleaner stuff.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
If you run the old style silicon covered gasket you may get some inside your cooling system. Specially if you have to scrape off the gasket from the cylinder head surface, hard to keep it out of the wather jacket. I change the coolant once a year at a minimum all the black stuff I had in there from when I blew the head gasket is long gone. With the silicon gasket I have used gasket remover, spray on, let it sit for 15-20 minutes, spray some more wait a few minutes, clean off with a cotton rag.
The new version of the gasket is all metal so the black stuff in the coolant is a thing of the past.
kinger
- Jan 17, 2005
- Clear Lake, IA
Hey rxrider - do you have a easy to way flush the system or do you just make a huge mess like I do?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Hahahah I sure do... I put a collector underneat the sled on the left hand side just in front of the running board cooler and detach the hose underneat the secondary clutch, loosen the hose and try to point it into the collector as fast as possible to reduce spill.... impossible LOL
Then I repeat the procedure on the right hand side... but now there is way less fuids left so the spill is bearable. You may open the rear end bleeding screw and drain that first, leave the bleed hole open, speeds up the drain process making more spillage LOL
kinger
- Jan 17, 2005
- Clear Lake, IA
I got a little pump off ebay and might try to make a atachment to pump coolant through the system from say a clean 5 gallon bucket or something. Sure wish there was a easier way to do it.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
whatever way you drain coolant... you'll end up with a mess on the floor.... that is an unwritten rule!
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
so true mulot, written in coolant on concrete floors LOL
