tshot12
- Oct 4, 2015
- Chicago
- 2006 Yamaha Vector ER
2006 Vector ER:
Hello, This is my first time rebuilding a skid and I need help with 2 part #s. I just want to make sure I'm ordering the correct parts.
1. It is the white plastic collar the sits on the pivot shaft between the tunnel and the upper idler wheel.
I believe it is #38 on parts diagram??, confused b/c dealers want $17 for a .50cent piece?
2. same diagram, part #33 and #34, I only have one metal washer there when I removed the skid.
how do I verify which washer I still need? if any?
pics to follow....thanks for the help.
tshot12
- Oct 4, 2015
- Chicago
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
The white nylon spacers are #38 in the parts diagram. They list for around $20 so you have the right item. I would have never guessed they are that much! part number is 90387-25005-00. I have some good used ones here. $5 for a pair of them.
As for the metal washers they are two different diameter OD's. If you measure the diameter of the washer you have I can then tell you which one you are missing. I would have the washers here too.
