Turk
Tech Advisor
Troops
To-day I had the opportunity to clutch & drive a 05 RS Vector with a simon,s CPR turbo. This package is a very smooth deciptively fast package. The turbo is 100% undetectible until you hit the throttle hard. We never went over 7.5 pounds boost due to unavailabilty of a boost guage.
OK....on our 1000' test strip the sled ran 198 kmh(122.1mph) on the speedo. Unfortunately the fastest sled we were able to test against was a buds tweaked, clutched 02 800 MXZ. The Vector roasred the track on holeshot..even at 3k engagement. At the end of 1000' the Vector was approxiamately 15-20 sled lengths ahead of the 800 doo.
The stock clutching was tossed & I got lucky & got 8500 rpm solid on my 1st try(I do get lucky!!!) with my set up.
My one bud with a very strongly tweaked Mach Z admitted his sled hit 180 on the speedo in this same distance! Sled works amazing with no lag & low boost was pretty strong. we rode it all pm on pump fuel with no probs!
Turk
Tech Advisor
A special thanx to Dennis Bellefleur for letting me dial in his sled!
Turk
Tech Advisor
More pics
Turk
Tech Advisor
couple more...sled coming off the test track.
Turk
Tech Advisor
The sled also needs moe gear...22/38 ain,t enuff. Traction was a huge issue with this gearing. I think a 23 or 24 top cog is the ticket. This is the most trail-friendly sneaky fast hi hp sled I have ever ridden.
Turk
Tech Advisor
Keep forgetting stuff...the sled ran all afternoon on our test track pinned to the handlebars on a hard pack track. No overheating, no warning lights no nothing. The only issues was getting a couple of the doo guys to stop riding the sled!!!!!!
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
Turk said:on our 1000' test strip the sled ran 198 kmh(122.1mph) on the speedo.
Is this the fastest you got all day? I mean this is a lot of money to spend to get a sled to go as fast as an RX-1. Unless this speedo is more accurate than the RX-1, which I suppose is possible. I would have thought that this setup should have produced around 170 - 180 horsepower and that you could have gotten to 120 - 125 on a gun, not on the speedo.
Turk
Tech Advisor
This was in 1000' & sled was running stock gearing. With more room & higher gearing there is a lot more available. Remember...this was running 1000'. When my 03 RX-1 was stock I would hit 170 kmh on the speedo in the same distance.
rx1ton
that was in a thousand feet! not on a lake
p0wd3rp1l0t
did u guys run it against the stock vector? also what does a so called stock rx1 with a turbo(no gear changes) run in a 1000 ft.?
I raced Jeff's turbo vector up in cable with my stock vector up in cable I would say a little less than a 1000ft and got distroyed.It also beat some f8's.
