snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I am getting ready to install the ngk cr10ek plugs in my 2008 nytro, what should I set the gap at? Thanks for the help.
AttakDog
Not really a gap on em, should be pre-gapped. You will see when you look at them
2008FxNytro
Yup, i just got mine locally and there really isnt a way to set a gap. install and go!!
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
yea i think they come gaped.
Blu2U2
The plugs came from Ulmer Racing so maybe they are pre-gaped?
AttakDog
They are a dual electrode plug. The grounds come in from the side and there is no gap setting unless you drop one and smash it to the electrode. Install and feel the power!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
.028" gap we check everyone we send out.
bradthebest
You should check gap on every plug you install never assume
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
bradthebest said:You should check gap on eery plug you instal never assume
I couldn't agree anymore!!
GT03235
Do these plugs really give more power? as anyone ever validated on a dyno?
I am following like a sheep because of what i have read. It would be nice to know
Blu2U2
I thought that I read that the dyno test showed gains of 2-3 more hp! I am sure if this is not true someone will correct me.
I think Ulmer found 1hp from them...which is better than nothing...I'm going to toss in a set this year based on Ulmers testing...if a good tuner recommends them, it's for a reason.
- Apr 17, 2003
- Menno, SD
- Menno, SD
2 to 3 hp gain over the stock plugs on back to back runs at Dynotech when we dynoed several years ago.
You have to replace these every year right?
