I thought that I would post this for all to see
The best practice is always low compression pistons,however,that's also the most work.If you are not wanting to take the rotating essembly apart to install pistons,the next best thing for you would be a head shim from Powderlites .I also recommend a set of chrome molly head studs together with a torque setting of 45lbs.That will help to give you some extra clamping force on your gasket and also the studs will not stretch like the stock studs as the boost comes up.When you are installing your head gasket,clean the block and head with laquer thinner or equivalent and install the gasket dry.Lube the nuts with a moly lube both in the threads and also where the nut turns on the washer.This adds 10lbs clamping force over being lubed with oil.We use Cometic gaskets in our engines because we require many different clearances,depending on the requirements of the particular engine.By the way,be sure that your head and block are straight within .0015".If you follow the above practices,you won't have any head gasket issues
