aksteepndeep
I went 14 1/4" centered over the windows
I cut mine down to 14-3/8" or just a tad under that . 14-1/2" is to wide. Look in the front of the tunnel and you can see what I'm talking about.
Kingsandman
Cut mine to 14 1/4. I set a step ladder on both sides of the table saw with the steps facing the sides of the blade. Then put an 8 inch piece of sewer pipe through the steps. On top of that, I run a piece of cardboard sono tube (concrete form). This acts like bearing and when the track is hung on that, I can do it myself. Both sides, 10 minutes including clean up. I've cut 5 so far and have found it way easier to have the track between the rip fence and the blade, with the piece to be cut off running loose beside the blade. I tried one with the piece being cut off between the rip fence and blade and it wanted to bind and moked like hell. Some guys turn them inside out but I've found it unnecesary, even with a 2 1/4" track. Good luck, just take your time!
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Out of curiosity do you then seal the sides with propane torch or does the saw generate heat, or maybe you don't need to at all.
Yamadoo
Yamadoo
Kingsandman
It sealed up pretty good, see for youself.yamadoo said:Out of curiosity do you then seal the sides with propane torch or does the saw generate heat, or maybe you don't need to at all.
Yamadoo
Johnmaster
- Jul 25, 2009
The WD40/Razor idea might work for cutting lug tips off but it won't make a dent in narrowing the track. The table saw method seems to be the way to do it, would love to see a video. Exactly what type of blade did you use and how high above the track did you set the blade height? I tried it once and made a bunch of smoke...
If anyone wants to see what I think is the fastest way to cut down the lugs on a track I have a youtube video of our last one. http://www.youtube.com/watch?v=SPa3cblkaTU Traction is terrible though so we made a nipper to make notches in the new blunt lug for more grip, worked great, did 4 machines.
Johnmaster
- Jul 25, 2009
Someone made this video and posted it on Youtube...
http://www.youtube.com/watch?v=-hmsFQ37APk&feature=fvw
yamahaman
- Jun 2, 2004
that last video is me got any question just pm me i tryed putting a turbo on and ended up with a junk motor holes threw the block not sure what happen if any one knows were i can get a motor or needs a parts sled let me know i live in iowa and will bring it to hay days if some one wants it
yamaha1
- Dec 16, 2005
- Shakopee, MN originaly from Fargo ND
yamahaman... pm'd ya.
Y1
Y1
Kingsandman
14 1/4, I've seen 14 5/8jet101ski said:Did you guys cut your tracks down to 14 inches or did you cut it a little bigger?
